Advice on Tires for '08 Rubi
Old Jul 12, 2010 | 01:13 PM
SteveA's Avatar
Default Advice on Tires for '08 Rubi
Gentelmen,
I have a '08 4 door Rubicon that I tow behind a motorhome. I've installed a wench and and set of 2" coil springs in the front to make the Jeep sit level. It's getting close for a new set of tires and want to go a bit larger/taller while keeping the stock wheels and a simular stock tread design. As I stated, it is towed and I don't want to go any higher on the lift. Your ideas would be welcome and thanks in advance.
Old Jul 12, 2010 | 01:36 PM
rizzosmith's Avatar
Veteran: Marine Corp
Default What size tires
Depends on how much clearance you need for the wheeling you're doing. If you don't need much, why not just 33's ? Your lift won't allow much more than that (probably 35's at the most, if it's only 2"). You may be able to find a close metric equivalent, if it's any cheaper. Are you keeping the stock rims ? I like the stance of a Jeep with a 2" lift on 33's, so that's my suggestion.
