Advise on front brake lines.
Next weekend going on my first off road trip since my Pro Comp 2.5" lift with MX-6 shocks. Do I need extended brake lines, front brake line bracket, bend lines down, or do you think they are long enough. I made a bracket for rear ones. Plenty of slack. Thanks.
Not entirely sure about the brake lines but I'm guessing TF took this into account with the bracket extensions for the rear and not the front. I worry about the axle breather tubes. Those things can pop off and then you may get water/debris into your axles which can cause pretty big problems.
Originally Posted by GunDude
So, I have 3"+ from my OME lift. If I get braided ext. front lines, what about the abs lines up front?
