AEV Beadlocks, WTH!!!
Old Sep 16, 2009 | 06:56 PM
Ryanc's Avatar
Default AEV Beadlocks, WTH!!!
I noticed this while torqueing the outside ring. 22 out of 24 bolts are grade 2. 2 are grade 8. So I googled this and found that I am not the only one. Are the grade 2 bolts sufficient?
Old Sep 16, 2009 | 07:37 PM
metaulic's Avatar
Yes. Bolt engineering is a science. Lower grade bolts are called soft bolts and will far exceed higher grade bolts in many ways depending on the load characteristics. Aev sounds like they do their homework so I do not recommend using anything else than grade 2 if that is what they provided.
Old Sep 16, 2009 | 08:30 PM
Living Still's Avatar
I've never really thought about using soft bolts on purpose... lol. Cool factoid. But, somethings still seems fishy with getting two grade 8s and a bunch of softies... I can tell you that a lot of the higher end beadlocks that are beat on by the pros are all grade 8. Give AEV a call.
~Casey
Old Sep 17, 2009 | 05:33 AM
Ramphog's Avatar
Yea why would they mix them in.... Give em a call....
Old Sep 17, 2009 | 05:34 AM
Ryanc's Avatar
Interesting. I didnt think of anything initially, because your only torquing these bolts to 15ftlb. Your explanation really makes sense though, it does seem that a more malleable or soft bolt would be a better option for a beadlock wheel.
Old Sep 17, 2009 | 05:47 AM
H315M4N's Avatar
Thumbs up
2x . . . give them a call and let us know what they say.
Old Sep 17, 2009 | 05:50 AM
racer83l's Avatar
I have read about this in the past... AEV's typical response, They dont know why there are bolts other than grade 8 on the wheels, and they will send out the appropriate replacements
Old Sep 17, 2009 | 07:39 AM
Ryanc's Avatar
Got a response from AEV, they want me to take a picture and send it to them. The guy at AEV stated that his supplier must have put in the wrong bolts. IMO that is not a small screwup. Anyways, I think I am going to use a socket cap like spyderlock uses, if that is feasible. Currently it is a royal pain in the a$$ to torque some of these hex caps because the machined ring is too damn small for the head to fit throught, even with a fabricated socket. Anyone know off had what size bolts are used.
Old Sep 17, 2009 | 08:42 AM
Ryanc's Avatar
What also happend is that the supplier did not supply the right size washers, this made it difficult to center the bolts and why a lot of folks have a difficult time torquing them. So I am going to get replacements shipped to me, hopefully I dont lose a bead going to 60mph.
