AEV Corner Guards and Bushwacker Flat combo
Looking for some help.....I currently have bushwacker flats on my 2 dr and would like to add the AEV rear corner guards, but want to make sure fitment won't be an issue. Anybody running this combo?
I zoomed a photo of my rear. The Fenders do overlap the corners, making the fenders stick out with a slight gap to the body line -- isn't a big deal to me, you'll need to trim the corner if you want a perfect flush seam.
They won't match perfectly unless you trim the corners. I have Warrior LED corners (and figure the AEV corners are same or very similar size) with Buckwacker flats.
You should decide what you want the corner armor for ? my sole reason was to recess the rear lights into the bodywork to avoid trail damage. The Bushwacker and AEV corners do not achieve that.
