AEV Correction Brackets with Teraflex 2.5" lift
Old Apr 20, 2013 | 10:30 AM
Zoso77's Avatar
Default AEV Correction Brackets with Teraflex 2.5" lift
I have a 2012 JKUS and finally made the leap for a lift and 35's. Ordered the TF 2.5", 18" Jesters, and 35" trail grapplers. I also found a used set of rubi shocks for cheap and plan to swap out when I install the lift.
Question is, are the AEV brackets a good option to avoid the "flighty" steering that some people have experienced? It's a DD and my offloading is limited to light trails and fire roads for camping trips so I'm trying to avoid the extra cost of LCA's.
Old Apr 20, 2013 | 10:37 AM
mrjosh's Avatar
I run the aev brackets with my teraflex lift. Made a huge difference in ride and the flighty steering.
Sent from my HTC One X using Tapatalk 2
Old Apr 20, 2013 | 10:43 AM
road_king's Avatar
They worked for me - the price was right and it was something I could install myself. Did mine about 2 years ago and just reciently flipped my drag link and it drives even better now. I bent two stock drag links but my new one will not bend so easy - better angle and stronger - which means I'll just bend something else!
Old Apr 20, 2013 | 10:49 AM
Mello03's Avatar
OP I have some practically brand new correction brackets that were run less than a thousand miles. I ran them with my AEV 2.5 lift for a short while. I recently went with a set of full adjustable arms, but the brackets were great. PM if interested. I will cut you a great deal.
Old Apr 20, 2013 | 11:13 AM
gunbo75's Avatar
Yes i do with the teraflex lift works great.
Old Apr 20, 2013 | 01:08 PM
Lost Dog's Avatar
I inquired about adding the AEV correction brackets to my rig (35's w/ 2.5" Teraflex) and was told it would not work and not compatible. Good to know this isn't true. Now, my Teraflex rides a bit stiff, with the correction brackets improve the ride?
