AEV front control arm Bracket
Old Jul 8, 2010 | 09:20 AM
sktdarkstar8's Avatar
Default AEV front control arm Bracket
now i know this bracket set is suppose to work with stock arms but i have all adj control arms.. should i still get this? i know it lowers the arms and makes them more parelle to the ground, so wouldnt that be an added benefit having them to help restore the arms to its original geometrey? do u guys think it worth the 99$ or just stick with what i got?
i just compare the dropping of the short arms and the long arms... the long arms are mounted lower and it achives a better ride quality, so wouldnt the short arms if you use this bracket?
is there any other drop mounts for the arms?
Old Jul 8, 2010 | 09:23 AM
Northridge4x4's Avatar
Sponsoring Vendor
If you didnt have adjustable arms I would say these would be perfect for you . But since you have the adjustable arms you dont need or want to get these.
David
Old Jul 8, 2010 | 06:06 PM
zoeydad's Avatar
I'm running them with a full set of JKS arms.
I had the JK dialed in with the arms only so I didn't need the brackets, but for $100 I thought I'd give them a try. The improvement in ride and braking is quite dramatic...they're staying.
Old Jul 8, 2010 | 08:51 PM
Default brackets
so even with adj control arms, you would recommend this? i hear a lot of good about them but i know they are really for using stock arms, so i read...
why do they do the front but not the rear with any kind of drop bracket?
