AEV High Steer
Old Feb 16, 2011 | 02:57 PM
gtucker0825's Avatar
Default AEV High Steer
Is there are write up for this?
Old Feb 16, 2011 | 04:49 PM
V10eatr's Avatar
h t t p ://w w w .aev-conversions.com/pdf/isheets/AEV-Nth_JK_HighSteer_Instructions.pdf
Old Feb 18, 2011 | 11:19 AM
If I have the Teraflex 4" lift with all adjustable control arms do I need to do step 10 when installing the AEV High Steer Kit?
http://www.aev-conversions.com/pdf/i...structions.pdf
Old Feb 18, 2011 | 11:27 AM
MikeyB's Avatar
No just make sure your washer and nut is bigger than the hole for the draglink. I have TF arms and 3" lift
I also did not install the shock mounts that came with it.
Old Feb 18, 2011 | 11:30 AM
So you left your LCA completely alone and replace the nut? Also, you didn't do any cutting around your LCA???
