AEV Nth Degree 3.5"
Old Feb 18, 2010 | 09:02 AM
Littlejon's Avatar
I would say to give David at Northridge 4x4 a call since his price with shipping will be lower than Quadratec. As far as the ride and handling of this kit, yes AEV did improve and expand the high speed performance aspect of the lift, but at the same time they did the same on the off road spectrum, so it is a good all around lift for what 99% of people are using the JK for.
The ride is firmer than stock, but with the progressive springs it is never harsh. Also with the progressive springs you will not get the harsh bottoming of the suspension that happens with other lifts. Yes this does make it harder to have a poser shot with one tire stuffed into the bumpstop, but it also will perform better off road. I know I cheaped out on my first two lifts, and now I am getting the AEV since it suits my needs quite well. I just plan on using a JKS upper control arm instead of the cams.
Old Feb 18, 2010 | 09:27 AM
BuckLisa's Avatar
I got the 4.5 AEV lift but have front LCA's from RockKrawler with 35's. I got aftermarket front and rear bumpers and it rides great.I say go for it!
Old Feb 18, 2010 | 10:26 AM
glwood6's Avatar
regarding cam bolts, they are nothing more than a cheap solution designed to keep cost down and i would not recommend using them as others here have already mentioned. in order to make them work, you need to notch out your control arm axle mounts making them into slots and reversing this in the future would require welding. the worst part about cam bolts is that if you wheel your jeep, they will come loose over time and that can screw up your alignment and cause other problems. i have recently seen this happen to blazer4949. new adjustable lower control arms is the best solution to setting your caster but they will cost more money.
X2. I tried cam bolts on my TJ, and ended up replacing them with adjustable control arms. They were a PITA to install, and I never felt at ease that they were not going to come loose at some point. Spend the $$ on adj. control arms if you can swing it.
Old Feb 18, 2010 | 10:37 AM
mkjeep's Avatar
X3, friends tj cambolts loosened up on his rear uppers and he rolled it one rainy night.
Old Feb 18, 2010 | 11:22 AM
mkjeep's Avatar
Originally Posted by EstianSwanepoel
x2
The guy that designed the lift is the same guy which designed the JK chassis. Which is one of the best ever!
I dunno, jeep engineers dropped the ball on alot of stuff, just read the stock forum section.
Old Feb 19, 2010 | 03:52 PM
Ciphercash's Avatar
I ordered the lift on wednesday and can't wait to install it! I want to bump my tires, 35 - 37, just not sure which brand and type to get. What would ya'll recommend? Will this lift provide enough clearance for 37's?
I was looking at either 36x13.50 Interco IROK Bias or a 37x14.00 IROK Bias. Pros, Cons?
Old Feb 19, 2010 | 04:09 PM
spinlock's Avatar
It depends on how heavy you are running. If you have stock bumpers, no winch, etc the 37's will fit fine since you get 4-5" of lift. If you are running fully loaded like the kit was designed you can still run 37's with minor rubbing.
I'm running 35s but I going to 36x13.5s for added flotation when I am done with with my driveline and suspension.
bly109's Avatar
the iroks run big. I think the 36 is actually close to 37.
Old Feb 19, 2010 | 04:25 PM
Ciphercash's Avatar
I'm currently running stock bumpers, but want new ones. As far as the front bumper goes, I don't necessarily need a winch (yet), so a relatively light but durable bumper, preferably without caps, light mounts, D-Rings and a hoop. Xenon fender flares and relatively light rear bumper with a tire carrier.
36's still good? What are you running right now?
I kinda like these too: http://www.quadratec.com/products/92606_10X_PG.htm
35x12.50
Old Feb 19, 2010 | 06:17 PM
Littlejon's Avatar
If you plan on running a 37" tire just flip your bumpstops in the rear to the 4.5" position and you should be all set. Depending on the tires you may (probably) need to trim the pinch weld a bit. If you plan on running a 37" MTR-K on an AEV wheel you also would want to get some wheel spacers, otherwise under flex you may rub on the frame and crontrol arms when turning.
