AEV Pintler balancing question
Old Sep 4, 2013 | 08:18 AM
2BAJeep's Avatar
Default AEV Pintler balancing question
For those that have pintler wheels. When you got them balanced did they apply the weights to the inside of the rim or the outside?
Thanks
Old Sep 4, 2013 | 08:24 AM
mattgt5's Avatar
Inside. The outside will beat them up. Scratches bad
JKred's Avatar
Sticky weights and clips on the inside of mine. Nothing outside.
Old Sep 4, 2013 | 08:27 AM
2BAJeep's Avatar
Thanks for the fast response. I went to a place near me and they told me he would have to see the rim before he could say he could put the weights on the inside.
My wheels should arrive tomorrow.
Think I'll try a different place for the mount and balance.
Thanks again!
Old Sep 4, 2013 | 08:29 AM
chad s's Avatar
Inside and 1 of mine wouldn't balance. Just out it on as a spare. Some other members have had problems with balancing
Old Sep 4, 2013 | 08:47 AM
Northridge4x4's Avatar
Sponsoring Vendor
You should not have any issues balancing the pintler. You may have issues because of the Tire itself. We install a ton of AEV wheels and have never had one we couldn't balance. We have had out of round tires before.
David
Old Sep 4, 2013 | 10:45 AM
Ryan0260's Avatar
David
X2, unless you have a bent wheel, which is very unlikely without suffering physical damage.
Old Sep 4, 2013 | 11:02 AM
chad s's Avatar
The tire mounting place showed me on the balancing machine. You could see the wheel was not perfectly round. They were brand new
Old Sep 6, 2013 | 01:18 AM
azsandrider's Avatar
I use balancing beads. That way when the tire starts to wear or has small chunks taken out on the trail the tire will re-balance it self.
The larger tire the harder to balance. I have 1 out of 5 KM2s that was not able to balance on my Pintlers with standard weights. Needed more beads that 8 oz too.
I also use balancing beads in my 22.5 RV tires. I have to go to a semi-truck tire shop for the tires and they only use the beads. They told me beads are better for the tire balance and all the trucking companies use them. They don't use the old large tire balancer in the shop any more unless a customer insists on it, then they charge them extra for that.
I also use balancing beads on my Goldwing MC. I've been over 120 mph in straight and curved sections in Death Valley with no problems.
Balancing beads ware used in some high end sport cars as well. The costs are coming down and I bet in the future that will be how all tires are balanced.
Old Sep 6, 2013 | 06:25 AM
Pushrod's Avatar
I would think AEV would replace a wheel that had a manufacturing flaw like out of round. It's worth contacting them and discussing the issue on the phone. At the price of the Pintler I would expect them to be usable and not just a tail gate ornament.
