AEV Pintler Wheel Rubbing Issues??
Old Jun 6, 2008 | 03:13 PM
stockYJ's Avatar
Default AEV Pintler Wheel Rubbing Issues??
I have a question for you AEV Pintler owners.
Do you have any rubbing issues?
Control Arms, Sway Bar disconnects, etc?
I just received my Beadlock wheels today and I measured the Backspacing to be 5.25". They advertise 4.7", but after I ordered them, I read that a few people had issues with some control arms. Some of them started adding spacers.
Any experiences would be welcome.
Last edited by wayoflife; Jun 6, 2008 at 10:31 PM. Reason: blacklisted manufacturer
Old Jun 25, 2008 | 08:29 PM
SH0RTBUS's Avatar
I have the non-beadlock Pintlers and have not had any issues at all while running 35s. How much lift are you running and have you re-centered your axles with adjustable trackbars or brackets? If your axles are shifted to far over you might run into issues. Also, if I remember correctly, the boxes for my wheels also stated a 10mm offset.
Old Jun 25, 2008 | 08:34 PM
skeptic's Avatar
cool table on this page.
https://www.rsracing.com/tech-wheel.html
Old Jun 25, 2008 | 09:04 PM
rumble bee's Avatar
I just got mine a few weeks back just as I was adding my 4.5 RE lift. I run 37" BFs and they are only about a 1/4 inch away from the rear control arms. I'm pretty positive that if I let any air out of the tires it'll rub. I thought about adding spacers but I've been advised against them due to stress on the axle. The further out the tires go the more stress there is. I haven't taken it off-road yet but hopefully this weekend I'll find out if they rub at all when I stress out the suspension.
Old Jun 26, 2008 | 08:19 AM
skeptic's Avatar
Originally Posted by putnam dan
It is my view that 5.25 backspacing is too much 4.5 or less is the sweet spot for tires of that size, with 35's and 3.5" lift no rubbing with 37's and 4.5" of lift a very very slight touch at full turn.
I thought AEV made various BS setups perhaps you got the wrong one?
They make a -10mm I believe which would be the ones to get.
Old Jun 26, 2008 | 08:22 AM
BLKRUBI's Avatar
I ran Ultra Thunders (5.25" of B.S.) for about 9-10 months with 35x12.50x18 Nittos and no rubbing issues and they were 5.25" of B.S. so it can be done. Just to be safe though, I'd stick with 5" or less.
