aev prenium kit
Old Jul 18, 2011 | 11:51 AM
ride2099's Avatar
Default aev prenium kit
Hi guy im looking for aev for my new suspension and i want to know the difference between the standard and premium kit and if iput the 4.5" kit do I need extented drive shaft or maybe tcase drop kit or im better with the 3.5 and are those kit are complete and what are good addition with ????
Old Jul 18, 2011 | 05:20 PM
ride2099's Avatar
any comments on those kit !!?! I want to order this kit this week if is good stuff
Old Jul 18, 2011 | 05:33 PM
mkjeep's Avatar
You can't drop the t-case lower on a JK. It's not set-up like a TJ. You can lower the skid though.
Old Jul 18, 2011 | 05:34 PM
ride2099's Avatar
ok I was not sure about this part !! thanks
Old Jul 18, 2011 | 06:06 PM
gludo's Avatar
The premium has the high steer kit, the procal, the jack base and some other smaller things. I think it is about $400 more. I think they renamed the kits too (not that it matters). The procal allows you to reprogram your computer for tire size, gears ect. if you did not know that already.
Old Jul 18, 2011 | 06:34 PM
rubi_kong's Avatar
If you have an auto I think you have to drop the trans skid. I remember seeing that in my directions. Check there website for the pdf manual. I'm sure its in there.
Great lift thou, loving my 3.5
Old Jul 18, 2011 | 06:42 PM
ride2099's Avatar
do you have needed to wedge the rear coil or the angle was good stock
Old Jul 18, 2011 | 07:02 PM
single's Avatar
The procal also helps center your steering wheel after the lift. Can turn on or off daytime driving lights, one touch turn signals, etc. Pretty cool gadget.
Old Jul 18, 2011 | 07:26 PM
BadPunkin's Avatar
I finished installing my 4.5" premium on my 4 door this afternoon. The premium kit has everything you need out of the boxes. Just follow the directions and you dont have to do anything crazy.
Old Jul 19, 2011 | 04:16 AM
ride2099's Avatar
the stock driveshaft fit with the 4.5 kit or they a little short
