Modified JK TechTech related bulletin board forum regarding subjects such as suspension, tires & wheels, steering, bumpers, skid plates, drive train, cages, on-board air and other useful modifications that will help improve the performance and protection of your Jeep JK Wrangler (Rubicon, Sahara, Unlimited and X) on the trail.
i ordered the procal,should be here today,i have 33s ,the power seemed ok,is that cause im not running 35s ?
I'm running 35's and power seemed fine around town. On the highway, however, it was brutal. Procal helped a bit with the shift points but I still have little to no power at higher speeds. OD i still useless. Hoping the Hypertech will help with that so I can avoid re-gearing for the time being.
33's the power loss probably won't be as bad but, depending on your gear setup, you will most likely feel it at higher speeds.
