AEV ProCal
Old Jan 3, 2011 | 11:42 PM
maroonjk2009's Avatar
Default AEV ProCal
Had a question...Has anyone used the AEV ProCal for ReCentering the steering wheel? If so how well did it work for you? Thanks
Old Jan 3, 2011 | 11:53 PM
nthinuf's Avatar
Works great. It shows you where the 'computer' thinks the steering wheel is centered, which isn't necessarily where 'you' would think it is centered.
Old Jan 4, 2011 | 12:29 AM
sa29560's Avatar
The ProCal is definitely worth every penny. Pretty much has the ability to correct every mod on your jeep without spending almost $400 on some other programmer
Old Jan 4, 2011 | 05:31 AM
Northern Wrangler's Avatar
It works very well.
Old Jan 4, 2011 | 06:49 AM
Alright cool good to know cause I bought one. I have took my Jeep in for an alignment 3 times and to get the steering wheel recentered and the steering wheel is still off so I'm going to try this and see if it helps. Seems like I'm having a problem when coming out of right turns because the steering wheel will be straight and then I will make a right turn and when comming out of the turn and going straight again the steering wheel is off so when I speed up sometimes the ESP will kick on since the steering wheel is not straight. I don't know what else it would be the axle seems centered everything is tight underneth. I'm hoping this will correct the problem.
