AEV ProCal
JKUR w 35s. Used AEV ProCal to program tires, axle etc. what about the front sway bar option? What should I run this at? On or off?
Originally Posted by Ripa777
(Post 4230920)
Originally Posted by jedg
(Post 4230925)
Do you have an e-disco sway bar that you've replaced with something else? That option turns off the e-disco light on the dash. As in if you remove your e-disco, the light on the dash will flash until it's disabled.
Oooo. Thx. So if I did Currie anti rock then I would turn this off ? |
If you do any mod that removes the e-disconnect then you use the procal to stop the dash light from flashing at you. There are some quick easy manual disconnect options for when the e-connect breaks but need a procal to turn the light off
Originally Posted by YYJ-JK
(Post 4230946)
