AEV Procal help please
Old Mar 7, 2013 | 09:15 PM
ghostjk's Avatar
Default AEV Procal help please
I got my AEV Procal and it is very easy to use. I've used it already for my tire size and it seems to have fixed my speedo. Do I need to set it to my new 513 gears if I have a manual transmission? Or is the new gear ratio only needed for auto's so that the auto transmission knows when to shift? Why do I need to enter new gear ratio with my 6 speed manual?
Old Mar 7, 2013 | 09:48 PM
BagOfDoorknobs's Avatar
I have a manual as well. You use the ProCal to set the gear ratios and tire size so that your odometer and speedometer will read accurately.
Old Mar 7, 2013 | 10:06 PM
ghostjk's Avatar
Ok I got ya. Can I use the Procal to shut off ESP or will I have to put a manual switch in like posted on other threads?
Old Mar 8, 2013 | 06:46 AM
jk_sea's Avatar
I don't remember the Procal being able to shut off ESP. It's been a month since I programmed my Jeep so I'd have to look.
But that begs the question, why do you want to disable ESP? You've got a button for it on your dash already. If you need to disable it for offroad use, use the button. It should turn off in 4-low anyway.
Old Mar 8, 2013 | 07:00 AM
jadmt's Avatar
JK-Forum Ambassador
I think the main reason you need to recalibrate the gear ratio if you changed gears in a manual is so your esp works properly. I think with all the sensors if anything is out of wack you can have codes etc.
Old Mar 8, 2013 | 10:14 AM
ghostjk's Avatar
I want ESP off bc with larger tires the ESP turns on when it doesn't need too. Like in tight corners etc. I've noticed it a lot when I went up to 33s. Now that I'm putting on 37s I'm assuming this will be exaggerated that much more.
Old Mar 8, 2013 | 10:49 AM
Ncb's Avatar
Ncb
There's no need to change the gear ratio in the computer with a manual transmission. Speed is sensed through the wheel speed sensor. ESP doesn't factor gear ratio.
Old Mar 8, 2013 | 10:52 AM
Ncb's Avatar
Ncb
Most likely the steering wheel isn't perfectly centered. Using the centering feature of the Procal with the Jeep on an alignment rack will get it perfect. I have 35s and 2.5" lift and never get the ESP activation in turns like some report.
Old Mar 8, 2013 | 11:06 AM
ghostjk's Avatar
Yes it has gone down drastically after centering my steering but would like it off completely
