Aev procal module? Axle Ratio?
Old Sep 15, 2012 | 07:22 AM
Momikey's Avatar
Default Aev procal module? Axle Ratio?
Ok so on my 2012 wrangler unlimited rubicon with 35" tires what should I set my aev procal module at for my axle ratio? 4.88?
Old Sep 15, 2012 | 07:43 AM
afpilot82's Avatar
JK-Forum Ambassador
Well, did you upgrade gears to a 4.88 ratio? If you're just trying to reset the speedo, measure the tires per the instructions.
Old Sep 15, 2012 | 09:09 AM
Momikey's Avatar
Oh ok thanks. So that option is for if you change your gears. Cool good to know. I already set the speedometer it worked good.
