AEV Procal question
Old Apr 22, 2013 | 05:26 AM
  #21
jadmt's Avatar
JK-Forum Ambassador
Originally Posted by JKUJeeper
Thanks guys for the replies. I have the right speed according to my GPS but when at 70 MPH my RPM's are at 3000 seems a little high. I thought the AEV Procal would change that if the Speedo was right on, which it is. If anyone is running the same tires and AEV Procal let me know what you set the Procal to. Thanks
if you are using an independant gps ie a garmin or an app on your smart phone and you are at 3000 at 70mph I agree either your tranny is not upshifting or you have extremely deep gears. with 32" tires to be at 3000rpm at 70 with a automatic pre 2012 you would have to have high 5.XX to low 6.XX gearing.
Old Apr 22, 2013 | 12:31 PM
  #22
watson190's Avatar
Originally Posted by Tooadvanced
x2.... .....
X3. Does anyone know if the speedo and stock in dash GPS are connected??? I just put on some 35 x 12.50 x 18 Nittos and my speedo and 430N are the same speed.
Old Apr 22, 2013 | 02:51 PM
  #23
Tooadvanced's Avatar
Yep uses the same speed sensor
Old Apr 22, 2013 | 06:36 PM
  #24
JKUJeeper's Avatar
I am using a Garmin GPS not a built in. I got my 2011 at the end of the build year so I think it should have the crappy mini van engine and 3.73 are my gears. It does feel like its not down shifting so tomorrow I'll turn off my overdrive and see if that helps. Again I thought the procal would fix the RPM's? oh well...
Old Apr 22, 2013 | 07:12 PM
  #25
CajunTiger's Avatar
Originally Posted by meschwenk
I had the same problem until I took the mesuerment from the center of the wheel to the ground. I got 16.5" then I X2 and came up with 33". I'm running 315/75 x 16 GY Duratracs which according to GY website should be 34.6". Now my speedo is right on with my GPS. I think it matters on how heavy your Jeep is and PSI in the tire.
I did that and measured 16.5 x 2=33" on my 35" Nitto Trail Grapplers...lol...From the ground to the center of the center cap....16.5. I guess I need to put 33" and I should be on the money huh!...
Old Apr 23, 2013 | 05:00 AM
  #26
jadmt's Avatar
JK-Forum Ambassador
yup. it is not uncommon at all.
