AEV Procal to Superchips Flashpaq
Old Feb 15, 2010 | 06:47 AM
Dex1's Avatar
Default AEV Procal to Superchips Flashpaq
I am currently running the AEV ProCal to adjust for tires, gears etc....
I want to go to the Superchips Flashpaq to be able to do more advanced programming....
My question is... do I have to revert all my AEV programs back to stock and not use the Procal anymore?? or can I use the two together????
Just asking... Thanks....
Old Feb 15, 2010 | 06:59 AM
Vernnz's Avatar
My vehicle has been programmed by another tuning product and now my Superchips programmer doesn’t work.
A Superchips programmer checks to make sure your vehicle is 100% factory stock before programming. If your vehicle has been programmed by another tuning product, you will have to return your vehicle to factory stock before attempting to use our programmer.
From the Superchips website Tech Support.
Old Feb 15, 2010 | 07:09 AM
Dex1's Avatar
Thanks Vernnz!!!
Old Feb 15, 2010 | 07:22 AM
BBirish's Avatar
cool, i was wondering the same thing
Old Feb 15, 2010 | 07:25 AM
seer1's Avatar
You can run both. I really like the daytime running lights and the stupid lane change blinker being off, but the Falshpaq does better with everything else. So like Vernnz says, return to stock with the Procal, program with the Flashpaq then put your Procal preferences back in on top. The Superchips doesn't mind the Procal if you're switching between tunings (e.g. Crawling to Towing) within the Flashpaq either.
