AEV ProCal and TPMS sensors.
I installed the AEV ProCal last week and turned the TPMS sensors off (flashed to 0 PSI). They work great and I no longer have the TPMS light on my dashboard.
Question is...
I want to change my current wheels. Now, since I set the TPMS threshold to 0 PSI, does the computer need to read the actual TPMS sensors?
Or...
Can I just install regular valve stems w/o TPMS sensors in the new wheel and still keep the TPMS sensor light on my dasboard off?
Question is...
Or...
I used the ProCal to turn off the stupid TPMS light. I am running Cragar 340's with no sensors whatsoever. The AEV guys are saying it will throw off an internal trouble code on the Starscan, but it will not be seen in day to day operation. You should just use the ProCal to return it to factory before you bring it for warranty work though.
No sensors here, and ProCal turns off the dummy light and dings. Another benefit, with the dummy light on, the dash will not fully dim, but with the light off, the dimmer works again! Thanks AEV!
Before I get my new tires mounted, just wanted to confirm this.
and this:
hows it working out for 08 folks without sensors but Procal TPMS set to 0?
Question is...
Or...
Question is...
Or...
and this:
