Aev procal tps
Old Sep 6, 2009 | 08:57 AM
grnjkrubi's Avatar
Default Aev procal tps
I want to just turn off the dreaded chimes on the tps. Do I just set to zero
on the procal.
Dip switches are set first 3 up and the rest down.
Is that correct?
Took the tire size just fine but won't accept tps setting.
Do I need to reset and start over?
Old Sep 6, 2009 | 09:02 AM
mkjeep's Avatar
I don't have the tpms, but I think you set it to 0. I know the settings I did do took a couple times resetting and doing it over.
Old Sep 6, 2009 | 09:27 AM
m(a)ce's Avatar
Originally Posted by grnjkrubi
Thanks, I will try that.
Can anyone say if the dip switch setting is correct
To set TPMS to zero:
First 3 up and rest down.
Old Sep 6, 2009 | 09:31 AM
grnjkrubi's Avatar
Thanks, just wanted to make sure that part was correct.
