AEV Rear Tire Carrier - Hi Lift Jack Solution!
Umm, its hard to see, but half of the powertank mount is there in the original post pictures. I made this mount as well. Underneath the spare is a circular piece of steel that I drilled out to fit over the studs on the AEV carrier. It has a piece of tubing welded on the middle of this piece that sticks through the center of the spare. The powertank has a similar fabricated piece except a male version. This male rod stock was machined down to slide into the tubing on the jeep and then drilled through and bolted. I leave the jeep side piece on all the time, and just remove the powertank side of the bracket when I am not on a wheeling trip.
Pretty simple, but no one made and sold a piece exactly how I wanted it, so I had to make my own. The good thing is, a mount of this type would work on any aftermarket tire carrier.
Hope this description helps, if I have time I may put some pictures up so it makes more sense.
Originally Posted by chrisswank
If you take a look at the back cover of the 2011 Q-Tech fall catalog you'll notice they have three new options for their bumper: splash guards, hi-lift bracket and 10gal fuel caddy! It looks like the wait is over! It does appear that your solution for the hi-lift bracket, as long as you can weld, costs a little less then $199...
Chris
Chris
