AEV snorkel
Old Sep 22, 2010 | 07:43 PM
762's Avatar
762
Default AEV snorkel
Hey guys just intalled my snorkel do you guys put some sort of silicone around were the snorkel fits into the air box i know its a fairley good fit just wondering if you seal things up .thanks for the info
Old Sep 22, 2010 | 08:20 PM
Sharkey's Avatar
Yep. Seal things up good and tight with some black silicone. If you didn't already do so, you should also extend all of your breather hoses (diffs, tranny, transfer case.) There are some good write-ups just do a search.
Old Sep 22, 2010 | 08:23 PM
RevyJKU08's Avatar
yep silicone the snorkel and airbox connect and the 4 factory box mountings at the bottom of the box and any other smaller holes in the box! And like MSkh20 stated get your breathers extended...BTW welcome to the deep divers club!
Old Sep 23, 2010 | 09:00 PM
beadbus's Avatar
Default Silicon the drain hole on the bottom?
I installed my snorkel and siliconed the air box connection both inside and outside so the silicones would touch and mend together.
Do I need to seal those bottom drain holes too ?
I extended my axle breathers ONLY as I was told the Auto trans was already high against the
hood firewall. Is this true?
QUOTE=TripleJeep_99;1860683]yep silicone the snorkel and airbox connect and the 4 factory box mountings at the bottom of the box and any other smaller holes in the box! And like MSkh20 stated get your breathers extended...BTW welcome to the deep divers club![/QUOTE]
Old Sep 24, 2010 | 06:16 AM
daubie's Avatar
[/QUOTE]
Yes, the instructions say to seal them
Old Sep 24, 2010 | 06:56 AM
RevyJKU08's Avatar
Yes seal up the 4 bottom drain holes to ensure it's waterproof. I would highly recommend you extend your Auto Trans breather tube and your transfer case if you are going to be doing some serious deep mud and water. Extend them up to the top of your firewall.
I have a 6speed manual but I have heard the Auto breather is pretty easy to extend it's just the Transfer Case that is a BEE with a itch.
Old Feb 5, 2011 | 02:16 PM
JDScott10's Avatar
Default ...
BLUF: Did you guys seal top of airbox to lower half?
Not to revive a dead thread, but I've got a dumb question, which I think the OP was getting at:
I sealed all four hols on bottom, and I sealed where the snorkel comes in, inside and out. My question, do you seal the top half of the box to the lower half of the box? Not sure if that's tight enough to be WATER tight, hence the question.
I doubt it, but did you guys seal the airbox breather hose and connection to the TB? I imagine with hose clamps, no need...at least that's how I'm playing it.
Old Feb 5, 2011 | 06:14 PM
RevyJKU08's Avatar
No, I never did silicone the top half of the box to the lower half. Also, I never used silicone on the hose from the stock box to TB and have had no issues.
Old Feb 6, 2011 | 06:20 AM
JDScott10's Avatar
Default Hua!
Gents, thanks for the reply. I was 99% sure about the hoses, but not quite about the box. You've straightened it out for me (sts). Besides, the K&N drop-in seems to have a nice solid rubber seal on the outside anyways.
