AEV Snorkle Install
Old Jul 3, 2009 | 12:31 PM
officer_vince's Avatar
Default AEV Snorkle Install
First off...wow what a PAIN IN THE ASS to install this...secondly IT LOOKS AWESOME!
First off...doing the hole-saw was not too big of an issue...using a dremel to do the rest of the cut....took a while...I went through literally 25 grinding disks to get this:
So with that done I figure lets paint...test fit...and uh-oh..since I am running the DAYSTAR hood latches...I need to grind ANOTHER 1/4" off the top of the hood..dammit! I am all out of grinding disks! So I use the sanding tool to sand the metal down...and burn my finger off....wonderful.
Then everything lined up...life was good...I mark the holes for the rivets...get ready to drill the 1/8" holes...get two done and promptly break the drill-bit off in the hood...F M L!!!
Get another bit and finish....loose two rivets...had to use self-tapping screws for two of them....other than that...
voila!
Doesn't look to bad for everything in the world going wrong....
Old Jul 3, 2009 | 02:03 PM
revolucion!'s Avatar
nice! a busted drill bit and some grinding discs isn't too bad of a loss, but sorry 'bout ur finger bro!
Old Jul 3, 2009 | 02:06 PM
Renzo Fighter's Avatar
nice i did one today also. Well i didnt do it, but i supervised well. Ill post pics of mine step by step.
Old Jul 3, 2009 | 02:37 PM
07rubisteve's Avatar
Nice, good job......will probably do this eventually.....
Old Jul 3, 2009 | 03:14 PM
Muffins's Avatar
Looks good, I'm still working up the courage to do that to mine, glad it all worked out in the end
Old Jul 3, 2009 | 03:58 PM
UGOTKERN's Avatar
If you use a Dremel, use the Dremel Diamond cutting disc..... All you need is one, and you'll still have it once you are done.
Old Jul 3, 2009 | 05:09 PM
07Rubi2dr's Avatar
good then you can go first through the water holes!
Old Jul 3, 2009 | 05:33 PM
haha.....Okay....not top of my list for priority mods....but when I do get one, I will go first. Plan on doing my long arm 4 inch lift, rear bumper, gears first... Gears will in with the next 1.5 months.
Old Jul 4, 2009 | 02:26 AM
pearl-drum-man's Avatar
Nice job, was worth the effort!
Old Jul 4, 2009 | 08:56 AM
rolly's Avatar
I love it !!!!!
