AFE 3" exhaust for the 3.6
A 3" single exit exhaust is too large for the 3.6L Pentastar. However the 2.5" stock exhaust is nominally too small. 2 5/8" would be the appropriate size if there was such an animal, while running smaller will increase low end torque but limit high end horsepower and larger will reduce low end torque while possibly increasing horsepower in the upper rpm range. Best to just leave it at 2.5".
The Viper/Vette use dual exhaust, where as the JK uses a single. A 3" doesn't seem way to big for a 285hp engine. I agree w/o a tune it may loss a bit of low end tq. Oh & thanks AFE, I just installed the 2.5". Why does AFE make 3 different exhaust for the 3.6?
Yep if it were a race car, the rig with a 2.5" exhaust would have a quicker 60' time and lower ET. The rig with a 3" exhaust would have slower 60' times, a lower ET but more mph at the finish line.
Given that these vehicles spend a lot more time in the lower rpm range, there isn't an advantage of having a larger exhaust.
Still probably to big for a 3.6. Maybe with a tune and 5:13 gears, wait a minute, I amy have to try that!
Can you explain the advantages of a single vs a dual (not a true dual, just single muffler and dual exit), and also explain cat-back vs axle back?
There are a bunch of online calculators for exhaust sizing that can be of benefit. The formulas work pretty well, in fact excellent, until you get into blown or turbo applications. My experience comes from some drag racing and of course some trial and error failings. In the end, I've always had better results with exhausts that leaned towards the small side, they're quicker and have better low end torque which is ideal for a street driven vehicle. Also, just to clarify smaller is quicker, bigger is faster, if that makes sense.
