AFE CAI Whistle?
Old Sep 5, 2007 | 03:46 PM
Run2Ga's Avatar
Default AFE CAI Whistle?
I installed my AFE CAI this weekend, started noticing a whistle when I start to press the gas. Goes away as I press harder. No noticiable trend with speed or rpm, just on the gas pedal position.
Just searched the forum, found that this might be typical for at least Airaid, possible all CAIs? Is this true, just a known side effect? Any possible remedies? Reposition the connector tube, tighten (or loosen?) the clamps, maybe turn the sensor? Wash the filter? If not, I'll have to keep riding and see if the whistle is too annoying.
I do notice more giddyup, a better rumble to the engine, and was previously getting ~280 miles per tank so I will find out if it helps my mpg.
Old Sep 5, 2007 | 03:51 PM
tjdUSCG's Avatar
That sound is one of the reasons the stock air intake was set up like it was. CAI's do that.
Old Sep 5, 2007 | 03:59 PM
DeepSky's Avatar
I've had my AirRaid installed for 2 days now and I haven't noticed any whistling or air tunnel sounding noises just that nice low growl.
I've even been driving with my windows down and with the radio off to make sure.
Maybe the whistle sound comes after a 'break in' period?
Old Sep 5, 2007 | 05:06 PM
cormac827's Avatar
yeah i got the whistle a bit, dont mind it really....you will get that with most cai's i believe....just how it is, but the sound is def worth everything that comes with it.
Old Sep 5, 2007 | 06:56 PM
Volley's Avatar
It is normal for every CAI I have had, but in all honesty my stock air box whistles too.
Old Sep 5, 2007 | 07:14 PM
zero2krazy's Avatar
I have a whistle when I just start to press on the gas. Thing is it sounds like its coming from underneath the Jeep on not the front. I had the whistle before I installed my Airaid CAI. I would love to find the reason for it and fix cuz it drives me friggin nuts.
Old Sep 6, 2007 | 08:24 AM
Run2Ga's Avatar
Thanks for the responses, you confirmed what I was afraid of. Just a typical side effect. I'll live with it for a 1000 miles or so, maybe try to tweak a little, then make a decision.
Old Sep 6, 2007 | 08:29 AM
bly109's Avatar
Do you have a 6spd? Ours does it too when the clutch is out. There is a TSB for it, but some forum members posted that the TSB fixed it for a few weeks and then it came back. I'm waiting awhile before I take ours in, its really not to annoying unless we are thinking about it..
We have the AFE and yes it whistles... I kinda like it... But I have read on here awhile ago that someone kept readjusting the airtubes until it went away. It was alot of trial and error.
Old Sep 6, 2007 | 08:58 AM
zero2krazy's Avatar
No i have an automatic. That sucks it came back. I press hard on the grass just so I don't have to hear the whistle.
Old Sep 15, 2007 | 06:02 AM
I've got an Airaid and the whistling has been driving me bonkers. Do people still say that? lol Anyway, I have tightened, loosened, adjusted, etc all of the clamps. hoses, still have the whistle. I thought that perhaps because the Airaid is made of plastic, that perhaps the plastic was flexing a bit when it's being tightened, and thus creating a small gap which could cause the whistling. I looked and looked and retightened and finally removed the CAI all together. What I found was that with the CAI off and nothing attached to the throttle body, that when it's in drive (I've got an auto) and you give it gas, the whistle comes in at the same point as with the CAI. So it's a question of something with the throttle body and not the CAI itself. The reason I believe it's not noticeable with the stock intake is because it's more restrictive, allowing in less air to create the whistle. When more air is allowed in the whistle becomes more pronounced. The whistle with the intake completely off was more noticeable than with it on. I didn't drive the car, just held the break and gave it gas to get it to the point where my whistle comes in (1900rpms).
I'm not sure what can be done, if anything to correct this. It might just be a trade off. Restricted airflow and no whistle or better airflow, growl, etc and dealing with the whistle.
As of now since I have decided it's not the AirAid, I'm on the fence about whether I should just put the stock housing back on, because the whistle annoys me so much. Mine is of a high pitched variety that sounds rather like squealing brakes. I however know the whistle is there and listen for it. A friend was in the car and he didn't notice anything really.
So, I recommend people attempt adjustments, but if you've tried every possible combo of adjusting, give it a shot with no intake at all, you'll probably hear a whistle as I did.
