AFE Y-Pipe on 2 door
Hi everyone !
I'm planning to put a 4'' Teraflex Long Arm with 37s on my wrangler.
Before doing that, I want to solve the exhaust crossover problem on 2012 JK. Teraflex explain it in this video : http://www.youtube.com/watch?v=oKBlEpMaJC4
For me it seems that the spacer are only a workaround to the problem so i'm looking for this : http://www.quadratec.com/products/17121_0300.htm
This pipe actually move back the Y between the transfer case and the OEM skid plate.
Quadratec say it can fit a 2 door Wrangler, however the manufacturer web site says it will only fit a 4 door.
Does any of you have installed this pipe on a 2 door or have enough knowledge to say it will fit ?
I have done many research on the subject but always come up with informations about 4 door JK.
Thanks
Thanks
Thanks David.
Is the spacers will allow full flex without touching the exhaust on a 4'' lift ?
I'm planning to change my driveshaft at the same time as I install my lift so i'm only talking about the exhaust issue.
If the spacers isn't enough. Do 2 door owners have another solution ?
