After Procal question. 2012 auto on 4.10's and 35's
Old Jan 11, 2012 | 06:54 PM
cody6597's Avatar
Default After Procal question. 2012 auto on 4.10's and 35's
Trying to reset my 12. I am running 315.75.16 MTR's. I measured them at 34.25 in height from the ground and on the jeep with full weight. Gave it a go to see my rpm's at 70 and came in at almost 2700 rpm. Jeep is an automatic on 4.10s.
2700 rpm seems high to me and the 12 conversion chart shows I should be running around 2200 to 2300. Whats everyone else seeing after ProCal with this set up?
Thanks.
Old Jan 11, 2012 | 06:59 PM
OutlawJK's Avatar
Do you have a hand held gps
You can verify speed with
Sent from my iPhone
Old Jan 11, 2012 | 07:01 PM
scooby snacks's Avatar
Subscribed. You may want to hit up JPOP he has a lot of experience with this.
Old Jan 11, 2012 | 07:02 PM
OutlawJK's Avatar
2700 is what mine was before 35" tires
Sounds like it needs re calibrated
Again
Sent from my iPhone
Old Jan 11, 2012 | 08:02 PM
jkjacksonjack's Avatar
I've got a 12, auto, with 4:10's. My tires measure at 34 in. At 70 I'm running at about 2600 0r 2700 rpms after the Procal
Old Jan 11, 2012 | 08:03 PM
cody6597's Avatar
Originally Posted by Raiderfan001
Are you supposed to measure the tire from the ground? I thought they measured the circumference.
If these are the same ones they have it as a 34.8" http://www.4wheelparts.com/Tires/LT3...n=GDY750554326
It says to measure from the ground fully weighted.
Old Jan 11, 2012 | 09:42 PM
Denny2565's Avatar
I had 315/75/16 MTRs on my '07 and they measured 34.25 on the ground, so you're ok there. I've got trail grapplers on my '12 measuring 33.75 on the ground. I've also got 4.10 and with stock tires, I ran about 3,000 rpm at 70 mph. With the trail grapplers, I'm around 2,500 rpm at 70 mph.
Old Jan 12, 2012 | 07:24 AM
bo9roadking's Avatar
My 2012 (4.10 gears, BFG 35" tires that measure 34" mounted, and ProCal) is running about 2350 rpm at 70 mph. I don't understand the wide rpm ranges getting posted with similar diameter tires and gearing unless the ProCal programming didn't work.
Old Jan 12, 2012 | 07:35 AM
MTG's Avatar
MTG
Subscribed.
Old Jan 12, 2012 | 10:54 AM
JE8154's Avatar
I have a Manual 2012 so I didn't have an rpm issue but I did have a speedometer/odometer issue. I found on here somewhere that you're supposed to only measure to the top of the shoulder from the ground. Not all the way to the top of the tread, this gave me around a 1/2 inch difference in where mine was set and how it is set now. This change has seemed to fix my problem. Let me know if this helps.
