Aftermarket Diff covers question(s)
Old Mar 10, 2011 | 03:27 PM
mcarr261's Avatar
Default Aftermarket Diff covers question(s)
I have Dana 30 front and Dana 44 rear and looking at Riddler covers. Should I use RVT or Lubelocker gaskets to seal? Also, should I go with regular gear oil or synthetic?
If anyone also has a different suggestion for brand of covers, throw that in too.
Thanks
Old Mar 10, 2011 | 03:28 PM
wazooz2424's Avatar
lube lockers are reusable, RTV seems to give a more flush seal with less chance of prying the diff cover on a rock. id use synthetic since you will already be in there and cleaning the housing out.
Old Mar 10, 2011 | 03:32 PM
Strong Bad's Avatar
Had the Riddler covers with LubeLockers when I had 44s without any problems. Using RTV on my Dynatracs now. Either way you should be fine.
Old Mar 10, 2011 | 03:42 PM
mcarr261's Avatar
Thanks for the quick replies
Old Mar 10, 2011 | 04:27 PM
Olean NY Jeeper's Avatar
I just got ARB covers and installed lube lockers. I asked my mechanic after he did my regear who specializes in off road vehicles (thats all he does) which fluid to go with and he recomended a name brand regular dyno oil. Says synthetic is fine for engines but diff should have regular oil. He said that dyno oil pulls heat from the gears more effectivly. I beleive him since I really trust him. I also have a warranty so I am followng his instructions.
The lube lockers have not leaked a drop. I cannot recomend ARB covers enough, they are premo quality and the dip stick is a nice feature. It also has two REALLY strong magnets, the dip stick and drain plug. Having extra magnets in ur diff cant be a bad thing.
Old Mar 10, 2011 | 04:45 PM
Mud Pie's Avatar
I put Rancho Diff Cvrs on both my front and rear 44's using Lube Lockers.
After a few months I noticed that the front was leaking and then later the rear. Some of the bolts were loose so I re-torqued the bolts and was fine for 6-7 months, then I noticed another leak in front and the bolts again were loosened.
Can't figure out why this is happening. Just have to keep monitoring garage floor for drips and then re-tighten.
Old Mar 10, 2011 | 04:57 PM
River Runner's Avatar
just installed riddlers sat. , low profile, no interference with anything, go syn. lube, and get a few cans of brake cleaner to clean out the housings. give northridge a call on thse riddlers(great price) DO NOT BE TEMPTED TO FILL THE DIFF TO THE FILL PLUG(restrain yourself) 2 qts front and 2 qts rear. i ran the lube lockers but rtv will work just the same. its all in what you want. and to the post above me blue locktight never hurt anything
Old Mar 10, 2011 | 05:54 PM
dubyas-eep's Avatar
I just threw on ARB front and rear diff covers last weekend, came with lube lockers and bought some spend Royal Purple. They are solid, I mean solid
Old Mar 10, 2011 | 06:07 PM
betjeep09's Avatar
So did I. But this was about a month ago. No problem so far. Got them from northridge as a package deal. Pretty sweet
Old Mar 10, 2011 | 06:14 PM
dozerjk's Avatar
Not to highjack the thread but how good is the seal on the Arb dip stick???were it goes into the cover!!
