Aftermarket Throttle Body
Old Sep 14, 2011 | 08:15 PM
rhinonemec's Avatar
Default Aftermarket Throttle Body
Anyone out there put on a new throttle body yet. The lower right bolt area broke on mine so I gotta replace it soon. All I can find is OEM thru the stealership. Can't seen to find any aftermarket throttle bodies. Any ideas?
Old Sep 14, 2011 | 08:41 PM
jeeeep's Avatar
Viper TB fits and seems to have noticeable improvement - as soon as I figure out which way to adjust timing with SuperChips I'll install it.
I hear SC and Viper don't mix well, without SC tune Viper self adjusts fine and runs good...may need CAI sleeve coupler if you run one
ht tp://www.moparsupercenter.com/viper-throttle-body-for-you-viper-or-07-to-2011-jeep-jk-s-with-3-8-black-53032837ab.html
Old Sep 15, 2011 | 03:41 AM
Ryan0260's Avatar
It will lean it out too much with both...
Old Sep 16, 2011 | 02:15 PM
rhinonemec's Avatar
The OEM TB assembly is 209 and the gasket is 32. I guess it's not bad, but it would be cool if someone made an aftermarket plug and play TB.
Old Sep 16, 2011 | 02:49 PM
CJ7nvrstk's Avatar
Vet Army
I have been running a viper TB on my JK for almost a year now with no problems. That includes a road trip to Moab and my normal driving as well.
Details in sig.
Old Sep 16, 2011 | 02:53 PM
Bubblegoose1's Avatar
Details in sig.
Same here. Also running Trinity Diablosport tuner.
Noticeable improvement off the line, throttle response is dead on (no need to waste money on a Sprint Booster), 1 - 1.5 mpg increase, and auto transmission holds gears longer and gains more RPM range.
Old Sep 16, 2011 | 03:01 PM
Jollydodger's Avatar
I run the Flashpaq 87 tune and viper TB with no problems. I have about 5000 miles with this set up.
Old Sep 16, 2011 | 03:05 PM
Jeepnut67's Avatar
Question
What tune are you using, if I may ask? I just got the Diablosport Predator and would love to add the Viper throttlebody if I won't have any problems
CJ7nvrstk's Avatar
Vet Army
I had the same results.
Old Sep 16, 2011 | 03:13 PM
I have run the 91 Performance, MPG Boost and 87 Performance tune. I can't vouch for usage with a Predator, but I can't see much if any change between the two. You can contact Frank at Diablosport; very helpful.
