Air compressor fit on bracket?
Old Sep 2, 2012 | 06:43 PM
CrazyJK's Avatar
Default Air compressor fit on bracket?
I Have a masterflow air compressor (cheap, shitty pep boys compressor) but since it is bigger than most compressors out there I'm not sure it will fit any in engine brackets? Has anybody put one of these on a mount in the engine(for oba) I will only be using it to fill up tires. The base pegs are approx. 3.5 in wide by 8 in long
Old Sep 3, 2012 | 06:07 AM
CrazyJK's Avatar
Bump........
Old Sep 3, 2012 | 06:41 AM
c17loadmaster's Avatar
I recently saw a picture of someone selling their compressor mount and it was this same compressor. They used a dominion offroad bracket and the hard wired the compressor to the battery. It will work fine. I have a smittybilt compressor that looks identical to yours. The bracket is only 50 bucks, so I say give it a try. I am going to do it soon also.
Old Sep 3, 2012 | 06:48 AM
SBEII's Avatar
It was a Smittybuilt superflo and it looked the same. It's also very and I mean very similar the Viair compressors. It is mounted under my hood now. I'm not sure which bracket it is, as it doesn't have any markings on it. I think all the mounts are pretty much the same.
ID:	361567   Click image for larger version
Old Sep 3, 2012 | 06:53 AM
tslewisz's Avatar
I have a similar setup. My mount is from Sinister Fab.
Old Sep 3, 2012 | 08:14 AM
CrazyJK's Avatar
Thanks for the advice, I'm gonna go ahead and order a dominion off road mount then
