air sensor
Does anybody know how to turn off the air sensor lite because i would like to run less air in my tires right now i have 35'' tall tires i'm running 35 pounds if i run less the sensor light comes on
Originally Posted by FrankTheTank
ProCal made by AEV is the cheapest solution. You can also calibrate your speedometer and customize your daytime running lights and more.
You realize that going to a taller tire made your speedometer inaccurate, right? And your odometer? And your mileage? Or not...
In addition to the TPMS Disable feature, both the ProCal and Flashpaq have functions to set new tire sizes and gear ratios into the JK's computer. This will 're-calibrate' the speedometer, the odometer, and your mpg's will be more accurate.
They both have some other great features as well.
