Which air shocks for snow plow sagging
Guys I have a 2012 2 door sport that sags when I hook up my snow plow- which air shocks do you rec. and what is the part numbers I should look for- thks
Air shocks are not good for that purpose as it will put all the added stress on the shock mounts.
Get some Firestone or Airlift airbags that go inside the coil spring. They are relatively easy to install and won't affect your ride when they are deflated.
Timbrens are another option but they will affect your ride wether you have the plow on or not.
Lots of good info on Plowsite.com
On my plow rig, a 2005 suburban I use Timbren suspension. Works awesome. Before I would flatten the front suspension, after, it sits on the timbrens and works great. Have a look, they do have a setup for the JK as far as I can remember.
