Air troubleshooting
Old Oct 10, 2010 | 02:40 PM
Red Rock Sam's Avatar
Default Air troubleshooting
I've been installing a viair compressor and a 2 gallon tank. Tank, compressor, pressure gauge, auto shut off... everything is working as it should. I put two ball valves on the tank, intending to have a front and a rear QD. Today I put in the front QD in the center of my light hoop. See photo.
There doesn't seem to be any leaks, in my lines, but when I open the ball valve, the QD is bleeding air when nothing is connected. When I connect a hose, there are no leaks and it functions fine.
Not sure what I did wrong. Not a lot of experience with air lines and connections. Any suggestions on how to fix?
Old Oct 10, 2010 | 02:47 PM
thrshr01's Avatar
Make sure the brass piece in the middle is not pushed in causing the air to come out. Push it down with a screw driver or something.
