airaid intake check engine light ?
Old Mar 29, 2010 | 06:30 PM
jeeper4life's Avatar
Default airaid intake check engine light ?
i just put an airaid cold air intake on my jk and the check engine light is on now..how do i fix/ reset it????
Old Mar 29, 2010 | 06:33 PM
fish's Avatar
From: Apple Valley, California Good ole Mojave Desert.
sure you didn't break your little oxygen sensor thing ya plugged in the air raid?
Old Mar 29, 2010 | 06:40 PM
Default airaid
i dont think so.. it was a little brittle though....so with that change the check engine light should not have came on .unless it broke??
Old Mar 29, 2010 | 08:37 PM
fish's Avatar
yeah that's correct. at least with my experience(putting 2 of these on my jeeps) i have not had a check engine light come on
Old Mar 29, 2010 | 10:42 PM
warlord's Avatar
how about checking the codes to see what is really wrong first
Old Mar 30, 2010 | 07:17 AM
fish's Avatar
good idea,it could just be some sort of coincedence
Old Mar 30, 2010 | 08:05 AM
runit3's Avatar
Also check all of the seals, sometimes the screw-on clamps can wiggle their way off of the lip of the intake tube under pressure causing an air leak.
Old Mar 30, 2010 | 09:00 AM
rickl's Avatar
Default check what code is active
check active code(if you do not have a obd 2 reader,there is a link here somewhere on how to check active faults and a code sheet)if it has anything to do with Airaid CAI install ,possible damage to intake air temp sensor swaped from stock intake piping to airaid,I have been running an Airaid intake for over 100,00km with no issues what so ever and very happy with performance increase,really woke the lil mini van engine up
