Airbag and clockspring recall. Issue with Superchips?
Quick question. Have an appointment to get three recalls dealt with tomorrow. The clockspring and passenger airbag will be fixed, along with the transmission skid plate being replaced (which I think I'll opt out of).
Anyway, will I need to set my jeep back to stock or can I leave my Superchips settings active? I have the 87 tune and tire size set to correct my speedo. Anyone ever had these recalls done? Will it be an issue to leave it as is? Thanks! |
Tell them you have a chip in it and it will not be a problem, at least for me it was not a problem getting any updates.
^^ that's exactly what I did- "I have a tuner in the vehicle so please do not flash any software without consulting me". They just unplug the battery, change things, then plug it back up. It was a solid hour for the clockspring replacement.
I've seen a few posts where not setting back to stock before going to the dealer caused problems with the tuner.
Just to be on the safe side, I always set back to stock before going to the dealer. It guarantees the tuner will see the dealer's updates, if any are installed, as the new "stock" settings when you reinstall your custom tune. |
I was told the computer needs to be reflashed after the airbag recall is performed so I set mine back to stock before I took it in.
Originally Posted by jtphoto JK
(Post 4300619)
Originally Posted by homeless
(Post 4300620)
Thanks for the help. I think I'll reset it just to be safe. Do I need to change the tire size back to stock or just reset the engine tune?
I don't turn mine back to stock anymore as it puts my Jeep into limp mode for some reason, pretty sure its because of my gears. So I just leave it and no issues.
