Airbags
Old Oct 19, 2008 | 05:25 AM
c90dan
Guest
Posts: n/a
Default Airbags
I'm getting ready to replace my stock front seats with Corbeau seats. The stock seats have side airbags. Once the stock seats are removed, will the passenger front airbag still operate in an accident? Obviously the Corbeau seats don't have all the sensors the stock seats have, but does that effect the front airbag?
Old Oct 19, 2008 | 05:33 AM
HappyCurmudgeon's Avatar
Eternal ***erator
to my knowledge, it will cause the passenger side airbag to cease functioning as the sensors for it are in the bottom portion of the passenger seat as well.
If anyone has more info, i would love to hear it. I passed on a set of mstercrafts once already because i wont do anything to disable the airbags.
Old Oct 19, 2008 | 06:19 AM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by putnam dan
Mastercrafts retain the stock under-seat sensor so airbags will continue to function as intended
yep, what he said
Old Oct 19, 2008 | 08:17 AM
c90dan
Guest
Posts: n/a
I didn't see anything on the Mastercraft site that said anything about the under seat sensor. Where'd you get that info?
Old Oct 19, 2008 | 08:22 AM
wayoflife's Avatar
JK-Forum Founder
you see the two silver boxes between the seat and seat rails? those are your air bag sensors and as you can see, they are still present with the mastercraft seat. i have personally talked to them about this and can assure you that your front airbags will still work with their seats.
Old Oct 19, 2008 | 08:40 AM
Eternal ***erator
dammit.
now i need to go kick myself.
Old Oct 19, 2008 | 08:45 AM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by HappyCurmudgeon
dammit.
well, if you have side impact airbags, i'm still not sure if you can use them as i believe none of your airbags will work if the side ones are disconnected.
Old Oct 19, 2008 | 08:46 AM
Eternal ***erator
I dont have the side airbags.
Should i use my sneakers, or steel toes?
Old Oct 19, 2008 | 10:02 AM
wayland1985's Avatar
So they still have the weight sensors in them too???
Old Oct 19, 2008 | 11:47 AM
c90dan
Guest
Posts: n/a
How do you like the mastercraft seats? Are they more comfortable than the stock? Is the seat area between the bolsters wider?
