Airing down with km2's
I run around 26 on gravel roads, 20-22 for normal off road and 15-20 for soft stuff. Went down to 10 psi once when stuck in some very lose gravel at a river mouth Only blown one bead in some deep tapered ruts because my track width is slightly wider than most other local 4wds. Going to play in some deep gravel this Sunday so will be down ton 0-15 but nothing to pop a bead on so should be OK
255/75R17 is the equivalent of a 32x10R17 or so... not sure what wheel size you have, but you should be able to go 12 psi with no problem whatsoever. Beads tend to go when you put a lot of weight on one tire that has been aired down significantly, such as when articulating in big rocks or in uneven terrain. Wider rims tend to blow beads easier than narrower, in my experience, but it depends on the tire size matched to it.
For most wheelin, I air my KM2's (35x12.5R17) down to 20 psi right off the bat to take the harshness out of the ride, then go down in 5 psi increments from there. Mud and rocks, about 15 psi is typical. For wheelin in snow, I air down as low as 5 psi for maximum floatation.
Of course the main thing is that if you air down, at all, for any reason, you should always have a way to air back UP again, AND have the ability to reseat a bead under trail conditions if you have to. There are probably tons of threads about all the different ways to reseat a bead on the trail, but most require a source of compressed air strong enough to not only inflate the tire but force it back on the rim again (with some help).
