Alignment?
Old Sep 9, 2011 | 09:30 AM
jugast's Avatar
Default Alignment?
I'm picking up a set of 33's this afternoon to upgrade my stock sport wheels. I'm not touching the suspension at all. Do I need an alignment since the jeep is gonna be sittin higher and the wheels are wider?
Old Sep 9, 2011 | 09:40 AM
nthinuf's Avatar
Nope. It may feel a bit different because of the bigger tires, but no alignment is needed.
Old Sep 9, 2011 | 11:01 AM
geman's Avatar
I just did that and lost about 10% on fuel economy, it also feels a little less power ( i have a 2dr 6 speed) someone told me i should regear the differencial to adjust the new wheel diameter. This will bring me the power back but loose more fuel efficiency, so , i will leave it as it is.
You will have to adjust your steering, wheels will rubb the sway bar a bit. its easy, look for the write up on JK project in this website.
Old Sep 9, 2011 | 05:11 PM
jugast's Avatar
Yeah I was just really curious about alignment. I'm fine in terms of gearing. Didn't feel like it lost much of anything with the 33's. I do get a strange wheel vibration it seems like at 60 mph. Might be out of balance.
Old Sep 9, 2011 | 05:19 PM
Ryan0260's Avatar
Yep sounds out of balance. Have them rebalance them. My 35's smooth at all speeds
Old Sep 9, 2011 | 05:32 PM
Markdsv's Avatar
No your alignment should be OK, if your Jeep starts to wander check your caster.....maybe you need adjustable upper control arms
Old Sep 9, 2011 | 05:47 PM
Black_JKU's Avatar
I can't believe he hasn't put up any pics (I've seen them in person)
They look great!!
2011 JKU- sport auto
Stock susp./ tires
Body Armor tailight guards
Old Sep 9, 2011 | 06:04 PM
jugast's Avatar
It does wander a little bit and and the steering wheel is a smidgen off. It starts at 60mph and as soon as your drop below that it goes away. I haven't pushed it past 60 to see if it will go away.
And I'll get some pictures up soon. Ran out of daylight.
