alignment always off after offroading
Old Aug 18, 2007 | 10:10 PM
peterko's Avatar
Default alignment always off after offroading
everytime i go offroading, my alignment is off. is that normal? am i hitting the bumps to fast or something?
Old Aug 18, 2007 | 10:33 PM
07JKX's Avatar
make sure the bolts are tightened down on the "aligment adjuster" in the front.
other than that... it should do it unless you bend/break something... or again.. the bolts are not tight enough
Old Aug 19, 2007 | 07:28 AM
wayoflife's Avatar
JK-Forum Founder
No, it is not normal at all. Are you still running stock suspension or do you have a lift kit on? If you have a lift kit on, you're bolts are probably not tightend to the proper torque settings and they are most likely coming loose.
Old Aug 19, 2007 | 04:55 PM
coltc2000's Avatar
X2
loose bolts is about all it should B
Old Aug 19, 2007 | 05:06 PM
edstroyer's Avatar
Originally Posted by coltc2000
X2
Or... GREMLINS!
Old Aug 19, 2007 | 05:23 PM
awfrode's Avatar
Lately I get an alignment after a good weekend of off roading .
