Alignment help
Old Oct 1, 2019 | 06:04 PM
  #21
resharp001's Avatar
Loved
Community Favorite
It sounded like you wanted to confirm that you did not bend a control arm. On the passenger side lower arm, measure from center of the bolt in the frame mount to center of bolt in the axle mount. That's your baseline. Measure the from same spots on driver's side. Length should be spot on. If not, measure a second time to confirm.
Old Oct 18, 2019 | 07:51 PM
  #22
jkrubcon's Avatar
The left side is 21 9/16 passenger side is 21 1/2. Weird, I would've thought since it's pulling to the left and that's the size I hit the deer on that the drivers side would be shorter.? Also just installed an adjustable track bar, seemed to help a tad but I didn't expect it to. Just always wanted one. 2" lift.
