Alignment or Not?
Old Aug 29, 2011 | 04:50 PM
MaddZach's Avatar
Default Alignment or Not?
Have a question for all of you lift pro's. I'm still pretty green to this Jeep stuff, but love every minute of it. I have installed a Teraflex 2.5" Budget Lift on my 09 4Dr X. Should I have the Jeep alignment checked? I bought the Pucks on the forum and didn't have directions. Any help would be great. Also, do I need an adjustable rear trackbar bracket?
Thanks in advance...
Paul
Old Aug 29, 2011 | 04:59 PM
nthinuf's Avatar
Adj trackbar -or- a trackbar bracket. (not an adj bracket )
Need? No. Want? Probably.
For the alignment, pretty much a waste of money until you get some adjustables on there.
Caster can't be adjusted with stock arms.
Axles can't be centered with stock trackbars.
Camber is not adjustable unless you go to adj balljoints.
Toe-In can be adjusted, but you can do it yourself if needed. (more than likely, not needed).
Centering the steering wheel takes a wrench and about 2 minutes.
Go down to the Write-ups area. Stickied at the top is an index. There is a great DIY alignment writeup in the Troubleshooting and Steering sections.
Old Aug 30, 2011 | 03:16 AM
Mark Doiron's Avatar
As said, not much to align on your Jeep. Here's some helpful information--only the toe in and steering wheel centering apply to you right now.
http://project-jk.com/jeep-jk-write-ups/basic-do-it-yourself-jeep-jk-wrangler-front-end-alignment
Old Aug 30, 2011 | 06:23 AM
wayoflife's Avatar
JK-Forum Founder
listen to these guys as they are right. with the amount of lift you're looking to install and with the components you have and won't have, there really isn't a whole lot that an alignment shop can do for you except take your money. anything that can be done, you can do yourself, with ease and for free.
Old Aug 30, 2011 | 06:25 AM
Hskr4x4's Avatar
Old Sep 5, 2011 | 04:03 AM
MaddZach's Avatar
Thanks for the advice... As always can always get a straight answer to any question.
