Alignment Question
Old Sep 9, 2009 | 06:55 PM
Dedduc's Avatar
Default Alignment Question
Ok this might sound crazy but hear me out. I did a Teraflex 3 inch kit with front lower flex arms and adjustable front track bar. After my alignment it seems like I lost power and mileage. I thought well maybe its just me,well tonight I moved my arms some and took it for a drive and it seems like all the power was back and my mpg on my dash were back up from like 13.5 to 16 on the highway. Am I crazy or what? Is this even possible?
Old Sep 9, 2009 | 07:36 PM
bigbluejk's Avatar
how much you talking? I guess in theory you could have set the caster so high that you drastically changed the toe and caused more friction between the tires and the road? maybe?
Old Sep 9, 2009 | 07:58 PM
mkjeep's Avatar
Fat lady stowaway hoped out.
Old Sep 9, 2009 | 08:09 PM
Dedduc's Avatar
I know it sounds crazy but it is true,motor is not working as hard.
Old Sep 9, 2009 | 08:26 PM
RedneckJeep's Avatar
You may have had the driveshaft in a bind.
Old Sep 10, 2009 | 09:20 AM
bigbluejk's Avatar
It should ne ez to tell on that one. if you ran it any length of time it should be pretty worn now.
Old Sep 10, 2009 | 09:25 AM
Ryanc's Avatar
I was thinking this as well.
Old Sep 10, 2009 | 10:46 AM
spinlock's Avatar
I concur. Too much positive or negative caster at some point will change the pinion angle excessively and cause the driveshaft to bind.
