Alignment Question - Differnt Toe?
Old May 2, 2011 | 10:34 PM
sanjosebass's Avatar
Default Alignment Question - Differnt Toe?
Last week I installed a 2.5 Coil Lift with adapters and new adj. trackbar and LCA's. I also added new wheels and 35" Duratracs and now I'd like to work on my alignment.
Looking at a report from an alignment shop it shows that my toe is:
Left: 0.5 degrees
Right: .017 degress
Tomorrow I plan on working on the caster myself (Going from 3.9 to 5.5) using WOL's Project-JK Alignment Write Up. I'll also look into getting the toe even on both sides as well....
Anyone know why the left and right toe would be different?
Old May 2, 2011 | 10:57 PM
ronjenx's Avatar
Did you center the axle with the adjustable track bar after the lift installation?
Lifting changes how long the drag link needs to be. Adjusting it will recenter the toe.
Old May 2, 2011 | 11:02 PM
This I HAVE NOT done. Maybe I'll just let the shop deal with it. Seems like the easy part is making the adjustments, the hard part is making sure you're spot on.
My ESP kicks on every now and again when I take a turn (both right and left) at higher speeds and I am hoping to correct that with an alignment. If it weren't for the ESP I'd be more that happy to be off a bit....
Old May 2, 2011 | 11:11 PM
ronjenx's Avatar
I suspected that, but forgot to mention it. That's caused by the drag link being the wrong length now, making the steering wheel off center.
I don't know if an alignment shop will even know about centering the axle with the adjustable track bar.
You may have to make some adjustments before you take it in. The steering wheel has a sensor that detects when it is centered. You may want to bring that up to the alignment technician, too.
Old May 2, 2011 | 11:18 PM
Thanks! - The alignment shop I plan on taking it too is a 4X4 shop and they have an alignment that includes the trackbar and LCA's (uppers too if you have them). Looks like I know what I am doing tomorrow.
Thanks for the help guys!
Old May 2, 2011 | 11:20 PM
ronjenx's Avatar
Sounds good. Let us know how it pans out.
