Alignment questions???
Old Feb 20, 2007 | 09:48 PM
kaffeene's Avatar
You would need to loosen the clamps on either end of the tie rod and rotate it clockwise or counter clock wise but why would you want to mess with this? Due to the new steering design, a toe-in adjustment is not necessary.
Don't you have to do an alignment after doing a lift?
Old Feb 20, 2007 | 10:22 PM
wayoflife's Avatar
JK-Forum Founder
This is a JK and not a TJ. On a TJ, because of how the steering is designed with the drag link and tie-rod being physically connected to each other, you do need to do a toe-in alignement. However, on a JK, the drag link is separate from tie-rod and so the toe-in will not change after installing a lift. All you really need to re-center your steering wheel and/or depending on how high you go, set your caster as well.
Old Jun 4, 2008 | 09:20 AM
rubiconjack's Avatar
doesn't the jeep have to be perfectly straight for the esp/bas light to turn off?
I have the ruib axles now. ESPOFF light comes on when lockers are engaged ... but ESP/BAS lights are still on, also when driving too. If i recenter my steering will it fix the problem? i had it before ai got the axles also.
I have a 4.5" RE LAK with 35" MT Baja Claws.
Old Jun 4, 2008 | 09:33 AM
Offroadme's Avatar
i did my alignment the best i could with a tape measure and some wood but i brought it to a local shop and they did it with the lasers.. a lot better. i feel safer driving now when going over 55 with no steering shake. i would def take it to have it done you can only do it so well with the eye and a tape measure
Old Jun 4, 2008 | 11:33 AM
huskerjk7's Avatar
wayoflife, I have the 3 ich ft lift with adj fronts (upper and lower), also the rear and front adj trackbars. Im running 35' tires. I was thinking that somebody said the camber needed to be 6 or 7 degrees. Is that correct?
Old Jul 15, 2008 | 02:37 PM
guinnessisgood's Avatar
I know I am not wayoflife but....
Camber needs to be a lot less then 6 or 7 degrees. I think it needs to be between .1 degree and -.6 degrees with a max difference of .5 degrees between the two front tire
Currently I have -1.1 degrees camber in my left front. The dealer says that front end alignment is only covered through 12,000 miles and I have 15,555 miles. I expect to have a disagreement tomorrow with my dealer.
