Alignment spec's help after lift
Old May 22, 2016 | 06:55 AM
ikaros's Avatar
Default Alignment spec's help after lift
Just recently finished installing my 2.5" lift and adj trac bars and adj lower control arms (front and rear)
I searched and see that most are recommending to target 5* of caster.
Is the target 5* for front and rear axles?
I am going to get my alignment on Friday and would appreciate any advise that will help me get the alignment dialed in.
Thanks in advance!
2015 Hydro Blue JKU
Old May 22, 2016 | 09:36 AM
ikaros's Avatar
Let me try a different way
Should target caster be 5* for the rear axle?
2015 Hydro Blue JKU
Old May 22, 2016 | 10:18 AM
kjeeper10's Avatar
Vet Army
Caster is a steering angle 4.5-5° is fine.
Rear pinion angle but with lowers i would leave them stock. Increasing the length can lower pinion angle. Plus you have a 4 door at 2.5 rear pinion is not a huge concern.
