Alignment Specs from Sears
Old Jul 20, 2014 | 05:02 PM
Trail Hog's Avatar
Default Alignment Specs from Sears
Besides the caster, does this look ok? I'm still getting a little bit of the ESP going off on some turns. Mods are:
OME 2.5" lift
35-12.50x17 tires
Synergy HD tie rod
JKS fixed lower control arms
JKS front and rear adjustable track bars
JKS adjustable sway bar quicker disconnects
Old Jul 20, 2014 | 08:34 PM
CerOf's Avatar
Originally Posted by Trail Hog
Besides the caster, does this look ok? I'm still getting a little bit of the ESP going off on some turns. Mods are: OME 2.5" lift 35-12.50x17 tires Synergy HD tie rod JKS fixed lower control arms JKS front and rear adjustable track bars JKS adjustable sway bar quicker disconnects
looks pretty good. A bit more caster will make it drive a touch better. But you're pretty darn close. With that much lift shouldn't make much difference. For the esp kicking on, the steering wheel must be off ever-so-slightly. My JK was pretty picky about the steering wheel being just right.
Sent from some string and a few tin cans.
Old Jul 21, 2014 | 12:51 AM
Mark Doiron's Avatar
What CerOf says: Adjust that steering wheel. It is extremely sensitive. If when you drive straight ahead you just think that your steering wheel might-could-maybe be just at a very slight angle, the Jeep will be unhappy. Adjust it.
