To all that have install there Driveshafts!
Old Sep 28, 2011 | 10:14 AM
GunDude's Avatar
Default To all that have install there Driveshafts!
I have the rear Coast DS and will be getting the front in Nov. I want to save the $$ and do this myself along with installing the TeraFlex ruca's, coil wedges, and coil retainers. My only concern is re-torqing the pinion nuts.
I do not have the funds for a dial inch lbs. torque wrench, to check the pinion nut preload. I was told by are fleet mechanic that the bar type are crap! So, from I have read, In short, I can tighten the pinion nut to 160 ft. lbs. and then an 1/8" farther, and will be good to go. Or, mark the pinion nut and go an 1/8" past.
What di you do!
Old Sep 28, 2011 | 10:58 AM
JayRud's Avatar
What di you do!
I like the torque wrenches at harbor freight. 15 $ will get u a good 150ft/lb click stop.
Old Sep 28, 2011 | 11:18 AM
highwayman's Avatar
A recent write up about Tom Woods driveshafts, stated it takes 200+lbs of torque to screw up the crush sleeve. In the article it said 180 lbs of torque and you're good to go.
Old Sep 28, 2011 | 02:25 PM
GunDude's Avatar
You have a link to that write up!
