Alloy USA Spacers 1.5" Tips on install?
Old Aug 11, 2011 | 07:32 PM
RubiconEurope's Avatar
Default Alloy USA Spacers 1.5" Tips on install?
Hi, I'm having a friend who owns an auto repair store help me install a spacer kit made by Alloy USA 5x5 bolt pattern 1.5" (red) on front and rear wheels tomorrow. Theyre made for the JK but what should I do while installing. and should I get wheels rebalanced or go into alignment again after the install?. Thanks in advance Im a search idiot so. excuse my thread.
Old Aug 11, 2011 | 07:40 PM
nthinuf's Avatar
Lock-tite, proper torque, proper maintenance
http://project-jk.com/jeep-jk-write-...ation-write-up
Old Aug 11, 2011 | 07:46 PM
Would it break the loctite after retightning after 100 miles?. i should get like the gasket washers between the wheel and hub out right? also is it really that important to torque exactly at 95-100 lbs? whatd happen if its tighter? like if we used a lug drill to tighten like ones at tire shops? thank you
Old Aug 11, 2011 | 07:48 PM
also is loctite absolutely necessary?
Old Aug 11, 2011 | 08:05 PM
nthinuf's Avatar
Only if you don't mind them loosening up and falling off, I guess.
Read the install guide, it will tell you to use a quality thread locker.
If you tighten them tighter, have spare studs handy to replace the broken ones with. And for the re-tighten, set the torque wrench a bit less than the required torque. That way it will start clicking (stop tightening) before it has the potential to break them loose.
Old Aug 11, 2011 | 08:07 PM
The alloy usa ones did not come with loctite. where can I get one? and which should I get. also do you think the lug nut tighetening guns have a torque setting when they click is that enough?. thats prolly 100 lbs. o well...thanks anyway..
Old Aug 11, 2011 | 08:13 PM
nthinuf's Avatar
Any autoparts store. It's only a few dollars.
The guns are impacts, aren't they? I would guess that it would have no problem at all breaking the locktite free. Get yourself a torque wrench, (I think they are around $20 at harbor freight?) and check the torque with every single tire rotation.
Then again, if you have no intention of doing any maintenance, do yourself a huge favor and return the spacers and order new rims with the appropriate backspacing...
Old Aug 11, 2011 | 08:22 PM
Dont have the money for new wheels which is why i used spacers. also yes impacts. are those right?. ok. what diameter is the torque wrench I should get...seriously though. is it ok to use impact to tighten them at first time around then use torque wrench to retighten? and I doubt it would break the lugs.. these are durable high quality stuff.
Old Aug 11, 2011 | 08:29 PM
Also its a jeep, not a le-mans car that has brakes that glow red hot...it wont be used to pull 1.2 lateral G's at a road course race track or autocross...I dont see how it can break lugnuts unless you drive down-right like an a-hole even when its done with an impact...just saying
Old Aug 11, 2011 | 08:38 PM
Also is it Loctite Threadlocker red 271 that would be used?
