Aluminum bumpers
Old Jun 29, 2015 | 04:07 PM
CajunTiger's Avatar
I Know GenRight makes them, but I'm not crazy about their tire carrier. PSC don't make aluminum bumpers, so I'm looking for a rear bumper with tire carrier with the same type of design as PSC. If PSC would make aluminum bumpers, I wouldn't be posting this thread. I just traded my 2011 2 door sport for a 2015 4 door Rubi and starting my build.
Old Jun 29, 2015 | 04:38 PM
DunnyBunny's Avatar
JK-Forum Ambassador
Well found a rear bumper just no tire carrier. Lol. Crawler Conceptz has a rear aluminum bumper but if you contact them the may be doing one with a tire carrier soon.
Old Jun 30, 2015 | 02:55 AM
CajunTiger's Avatar
I'll surely check on that. I been searching and ain't finding much to choose from. Thanks for the info....
Old Jun 30, 2015 | 04:46 AM
pbujku13's Avatar
RockSlide Engineering makes their rear in aluminum that they sell with a tire carrier option.
(I have the no tire carrier one)
Old Jun 30, 2015 | 08:46 AM
Invest2m4's Avatar
Genrights carrier is body mounted.
You are going to have a very hard time finding an aluminum bumper with integrated carrier. By the time you run thick enough aluminum, it will weigh as much as a steel bumper. Aluminum doesn't bend for crap, unless you use really soft stuff, which means lots of welding. The downside there is another unique property of aluminum. The weld is weaker than the base material, whereas with steel the weld is stronger. I personally would not ever run an aluminum bumper with an integrated swing-out carrier.
Why the focus on aluminum? I'm sure it isn't weight as there are bumpers using HST that weight very little. Rust concern?
Old Jun 30, 2015 | 08:51 AM
DJ1's Avatar
DJ1
Former Member
You are going to have a very hard time finding an aluminum bumper with integrated carrier. By the time you run thick enough aluminum, it will weigh as much as a steel bumper.... I personally would not ever run an aluminum bumper with an integrated swing-out carrier.
Exactly....coming from a Genright owner
Old Jun 30, 2015 | 08:58 AM
CajunTiger's Avatar
Genrights carrier is body mounted. You are going to have a very hard time finding an aluminum bumper with integrated carrier. By the time you run thick enough aluminum, it will weigh as much as a steel bumper. Aluminum doesn't bend for crap, unless you use really soft stuff, which means lots of welding. The downside there is another unique property of aluminum. The weld is weaker than the base material, whereas with steel the weld is stronger. I personally would not ever run an aluminum bumper with an integrated swing-out carrier. Why the focus on aluminum? I'm sure it isn't weight as there are bumpers using HST that weight very little. Rust concern?
Just a weight concern. My 2011 was a turtle with the weight so I'm just trying to keep the weight down is all.
Old Jun 30, 2015 | 09:09 AM
Invest2m4's Avatar
You'll have to run something like a Genright bumper and then either their carrier or something like the Teraflex or Crawler Concepts. Regardless, it is not some major weight savings. Check out the LoD Gen 4 bumper and carrier. They use high tensile strength steel. It is lighter and stronger. The entire bumper and carrier weighs around 110 lbs and is nearly bullet proof. You might be able to save 30 lbs more with some combo of aluminum, but there are far easier ways to save weight.
Plus, you are starting with an extra 100 hp. With the correct gears, it won't be slow. My 2013 had 37s on beadlocks and I was fully armored. With 4.88s, it was like driving a go-cart around town.
Old Jun 30, 2015 | 09:21 AM
DJ1's Avatar
DJ1
Former Member
My Genright aluminum carrier and bumper come in at 40 lbs total....
Old Jun 30, 2015 | 09:28 AM
Invest2m4's Avatar
Ok, lighter than I guessed. I'll skip the strength discussion...
