Am I sagging too much?
Lately I've gotten it in my head that the Jeep sits lower then some of the ~3.5" Jeeps I see and I do get the scraping feeling when going over some things that other folks do not.
Currently I have a 4" zone lift, JKS front track bar and full synergy front end. Rear has the OEM track bar with the lift bracket on the axle side. Could anyone take a look at the pictures and see if it looks too compressed or would benefit from an extra inch? Speaking with Zone they suggested getting the JKS ACOS units. Although at least 700 bucks to get that inch back, if I did indeed lose it, seems a bit much. Open to any suggestions, or if it is all in my head. Lift Query - Imgur Edit: Tires are 315/70R17 Duratracs |
My fully loaded JKU sits at 38.5" front and 39" rear with an AEV 2.5" and true 33's (measured from the same point as your pictures). Depending on the height of your Duratrac's I'd defiantly say you've got some sag going on. TeraFlex 1" spacers would be a much cheaper route than the JKS system.
I see a slight bow in the coils.. and you didn't use any sort of coil spacer other than the factory version?.
Originally Posted by Tripletsi
(Post 3985640)
Originally Posted by AngryRedBird
(Post 3985645)
Well depends on the weight.. how much weight are we talking? and what's the max weight a JKU can hold.. I think teraflex or alternative has a spacer kit which is beveled/angled spacer that forces the coiled up right.. I think at this point if you added spacers.. depending on how much of a spacer.. the coils might actually bow even more. I want to say something's off but can't figure out what.. Clearly you have the height.. just need to refocus on the coils.. might need a set of the coil retaining brackets too.
Could be the sway links are to short, might try to added a drop bracket on the sways. so something is retaining these coils from reaching their max height.. Think it's a miss match of coils, brackets, links spacers etc.. Unless this was all one kit.. |
All 4 coils are bowed. Are you on stock arms? Is your axle centered? Wedges will help in the rear but they aren't for use in the front.
Springs will bow on taller lifts. The rear can be corrected with wedges. The sway bar isn't the problem as noted above. I recommend getting a set of better quality coils vs. Zone coils.
2 Attachment(s)
Use the measurements in the attachments to see exactly how much lift you currently have.
(Post 3985671)
Well depends on the weight.. how much weight are we talking? and what's the max weight a JKU can hold.. I think teraflex or alternative has a spacer kit which is beveled/angled spacer that forces the coiled up right.. I think at this point if you added spacers.. depending on how much of a spacer.. the coils might actually bow even more. I want to say something's off but can't figure out what.. Clearly you have the height.. just need to refocus on the coils.. might need a set of the coil retaining brackets too. Could be the sway links are to short, might try to added a drop bracket on the sways. so something is retaining these coils from reaching their max height.. Think it's a miss match of coils, brackets, links spacers etc.. Unless this was all one kit..
I would replace the springs before I added a spacer or spent the money on the acos |
(Post 3985671)
Originally Posted by JE8154
(Post 3985679)
Originally Posted by Ncb
(Post 3985683)
(Post 3985684)
